EGR valve test
Old Aug 31, 2012 | 11:45 AM
ojohnny65's Avatar
EGR valve test
If I unplug the rubber boot on top of egr valve and apply vacuum pump should the valve hold vacuum solid, gauge does not move? I am doing this with the car off and the gauge does not hold but i can hear the valve lose vacuum? The valve is negative backpressure..stamped N. 1995 M6..143K miles.
Old Aug 31, 2012 | 01:15 PM
Re: EGR valve test
Yes, it should hold vacuum.
EGR
Old Aug 31, 2012 | 01:53 PM
ojohnny65's Avatar
Re: EGR valve test
EGR
OK...so mine is broke since I can keeping applying trigger and gauge just keeps flapping and not holding solid. Neg backpressure valve hard to find..summittracing will not ship until 9/11/12. Any ideas where I might be able to pick one this labor day weekend.?
Old Aug 31, 2012 | 04:10 PM
Re: EGR valve test
Have you tried any local part places. I would think it would be a common item.
Old Sep 1, 2012 | 06:26 PM
ojohnny65's Avatar
Re: EGR valve test
I have to admit..not sure what kind of egr valve I have since last time I changed did not know about ported vs pos vs neg. I believe I have a neg bac pressure sys for may 1995 m6 vin p car model. How do I know what valve type if I never checked the stampings on the egr? What kind of egr sys in my car? Pos or neg or ported?
Old Sep 1, 2012 | 09:40 PM
Re: EGR valve test
Just go buy what they say fits it. You don't need to worry about what kind it is. It should be the right one.
dfarr67
Apr 10, 2015 07:44 PM
edman
Mar 13, 2015 09:39 PM
jocamino
Dec 29, 2014 10:15 PM
Cam28_boy
Aug 6, 2002 08:40 AM
