EGR valve question
Old May 11, 2004 | 03:22 PM
Bow94z's Avatar
EGR valve question
how much are they? should i clean it up or buy new.
people say they get "surging " from a bad valve what do they mean by that?
this weekend, im gonna clean the MAF, MAP, change TPS, add a fan switch>>whats the easiest way to make one on a 94,any guides
Old May 11, 2004 | 06:09 PM
Bow94z's Avatar
ttt
Old May 12, 2004 | 03:43 PM
EviLBoX's Avatar
You can pull the EGR valve to see if it's still good. After you remove it just push the valve open/close and see if it leaks and is relatively easy to open/close. To clean it, spray some carb cleaner in the opening. If your vavle is bad you can get a new one for $40 or so.
Old May 12, 2004 | 03:50 PM
valter's Avatar
Yeah, check it. You can do it still on a car. Start it and push a diaphragm, engine should stumble or die. Then you can test it with vacuum tester or smth else to find out any pinhole leaks. Do a search, there were a lot of info on it...
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
jocamino
Dec 29, 2014 10:15 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
