EGR Stuck
Old May 14, 2004 | 03:02 PM
1FstFormulaV8's Avatar
EGR Stuck
My EGR is stuck causing fuel to be dumped HARD into the engine. I'm not getting an SES light from it either. I don't have the money to replace it right now. Would it be a good idea to take it off and get the diaphragm moving again? At least so I won't have a huge load up and backfire?
Old May 14, 2004 | 03:12 PM
valter's Avatar
Are you sure you can't force diaphragm to move while it's still on a car by spraying it with some stuff (brake cleaner or WD-40) and pushing on it?
Old May 14, 2004 | 03:14 PM
It was hot when I was going to spray some WD on it..It's cooling down now, then I'll give it a try.
Old May 15, 2004 | 08:52 AM
EviLBoX's Avatar
Just remove the EGR valve and spray some carb cleaner in it to clean up all the gunk, that should help.
Old May 15, 2004 | 11:03 AM
Bow94z's Avatar
can you remove the egr valve without taking off the manifold.
Old May 15, 2004 | 11:14 AM
Igniter's Avatar
Yes.
Old May 15, 2004 | 01:14 PM
ishz28's Avatar
How about this one. My EGR is 10 years old, I'd like to put on a new one, but striped the damn nut on the drivers side. Since you only have enough room to put a Q-tip between the bolt and the front of the EGR. I'd thought I cut the "Some of a bit*h" in half with a dremel. I've tried line wrenchs, box wrenchs, trying the next sized down wrench, even vice grips. I can't even fit an inverted torx back there to just take the whole stud out. I figured if I can get it in half, I can get the torx on there. Stupid, yes, but I don't want to have to pull the intake to do this.
Old May 15, 2004 | 10:27 PM
I sprayed some WD 40 on the EGR it's moving back and forth now. But for the most part I'm still loading up and backfiring. What could cause this? EGR not holding a vacuum? Perhaps I have another vacuum leak somewhere? If so, what and where would they be?
Old May 15, 2004 | 10:40 PM
Spinner's Avatar
Originally posted by 1FstFormulaV8
I sprayed some WD 40 on the EGR it's moving back and forth now. But for the most part I'm still loading up and backfiring. Would could cause this? EGR not holding a vacuum? Perhaps I have another vacuum leak somewhere? If so, what and where would they be?
I've got my EGR valve off my 94 sitting around. Paypal $10 to cover shipping and I'll send it your way. It's not doing me any good sitting around here, works fine.
Old May 15, 2004 | 11:46 PM
Ok. But I need to know what other things cause a load up/backfire scenario.
Old May 16, 2004 | 11:54 AM
valter's Avatar
Check your PCV valve, all vacuum line connections (especially to EGR solenoid and fuel pressure regulator - there is scheme on radiator cover sticker). Check your vacuum if possible. Are you sure these are not ignition problems? Plugs/wires are ok? If you have a OBDI - it's not very sensitive to throw any codes due to misfire. Check all sensor's readings with tester.
Old May 16, 2004 | 12:00 PM
Opti, Wires, Plugs, all are new.
I went out to take a look around. And I noticed some discoloration on the passenger side of th intake. It's sorta goldish in color. I looked around the other side of the intake. The discoloration is only over there near the 2 injectors.
marlar98
Oct 21, 2015 02:02 PM
68camaroboltz
Oct 5, 2015 11:56 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
