EGR solenoid removal???
Old Jun 19, 2005 | 09:47 AM
gamecockfan04's Avatar
Ive taken all the EGR componets off and put 3 block off plates on to cover the holes for the EGR componets, but can I remove the solenoid and put a vacuum cap on the intake piece? If so, do I just tape up the connector that is for plugging into the solenoid? If I need to leave the solenoid in there do I just cap the 2 lines?
Old Jun 19, 2005 | 10:24 AM
ulakovic22's Avatar
Re: EGR solenoid removal???
Yes, you can take it off and cap the manifold. You can leave the plug just hanging there or you can pull it back and tuck it into the harness or something. The noid is there to open and close the EGR based on manifold vacuum, so if your valve is no longer there to open and close you don't need it.
Old Jun 19, 2005 | 08:11 PM
You will probably get a diagnostic trouble code when the solenoid is removed.
HectorM52
Jul 30, 2017 11:46 AM
timmy39120
May 8, 2015 11:41 AM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
