EGR question.
Old Jul 9, 2006 | 01:54 AM
"White Knight"'s Avatar
EGR question.
I think I finally found my idle problem. I broke the EGR tube during rocker arm install...I am actually glad it's just this, only $20 fix.
From the factory do our engines come with a gasket on the EGR tube on the back of the intake manifold? Basically I am wonder if I should use one of these gaskets back there. I need one for on the header for sure, but I am unsure if I should use one on the other two connections. I just want to get rid of this vacum leak.
http://www.partsamerica.com/ProductD...pe=283&ptset=A
What do you guys think should I try these gaskets in all three locations?
I see shoebox's site has a little write up on it, but is it possible for the EGR valve to get stuck open?? I assume this would hurt your WOT performance? I just really want to look into my EGR and make sure it's working properly and not hindering my performance. I believe this leak definately was hurting my idle.
Old Jul 9, 2006 | 07:29 AM
The Engineer's Avatar
Re: EGR question.
The EGR tube manifold end has a gasket, however, the header end does not. EGR valve also uses a gasket.
http://www.cardomain.com/ride/2189634
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Latronaxe
Jul 20, 2015 12:00 PM
