EGR Question
Old Sep 9, 2004 | 07:33 AM
BigJustinZ28's Avatar
EGR Question
ok , heres an update , my idle is starting to seem a lil off and my exhaust has gotten a lil more poppy at times. The car is surging at idle a little bit sometimes. The EGR code is more persistant than before , I erase it and it comes back quickly . I think I have a evil EGR valve on my hands. Does this sound like something and EGR valve can cause ??? Also my friend (whos a mechanic) says to just take it out and clean it , is that usually the case on an LT1 ??
thanks , Justin
p.s. I checked my map sensor readings on my scanner and they seem more erratic than usual. Stumbling from 54 to as low as 46 where before it kinda hung around 52-54
Old Sep 9, 2004 | 07:51 AM
Re: EGR Question
It's possible to clean and reuse it, as long as the valve is functioning properly.
Old Sep 9, 2004 | 08:08 AM
Re: EGR Question
Hey shoebox , I was just looking at your site , my car has the syptoms of it being stuck open except for it hasnt stalled on me yet altho its come close. Do you think it is my EGR or the computer is tripping the code in error due to my headers etc. ???
Old Sep 9, 2004 | 10:28 AM
Bryan Smith's Avatar
Re: EGR Question
Same symtoms here, found out that my vacuum supply line was disconnected. Even though I reconnected it, the EGR system is still dead. And I'm still throwing a code 32.
Steve10 is getting $30 of mine to get the block off plates.
Old Sep 11, 2004 | 07:36 PM
Re: EGR Question
UPDATE
took the egr out and cleaned it , it seemed to be in very good shape , held vacuum and everything. Put it back on and Im still getting the EGR code. Any Ideas ???
Noenav
Mar 1, 2019 07:38 AM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
thenewkid
Nov 18, 2014 12:57 PM
