EGR Plate Problem??
Old Feb 27, 2003 | 01:18 AM
SVT Killer LV's Avatar
Thumbs down EGR Plate Problem??
So while I was taking my intake manifold off last week.. I notices that one my EGR block off plates was not blocking it all.. it was completely open... Other than a wicked vacume leak what else could that cause? Would it cause me to dyno lower than normal? I also noticed many of my intake bolts were loose! Thanks guys
Old Feb 27, 2003 | 01:30 AM
zyal8er5.slow's Avatar
yes
Old Feb 27, 2003 | 01:31 AM
any other opinions? perhaps a valid one....
Old Feb 27, 2003 | 06:02 AM
anaik's Avatar
Which plate was off? If it was for the exhaust gas tube there would have been no leak. I have never looked at how big the hole is into the plenum where the EGR valve goes, but I think you would have noticed a vacuum leak.
Old Feb 27, 2003 | 11:18 AM
The tube that goes from what used to be the manifold tube.. not the EGR hole
Old Feb 27, 2003 | 12:58 PM
anaik's Avatar
You're confusing me now. Was the plate on the end of the tube or on the opening next to the EGR valve opening? If it was on the manifold, no problem. That hole doesn't really need to be closed. People just cap it to keep the crud out.
Old Feb 27, 2003 | 02:05 PM
When you put in Hooker Longtubes and !Treehugging Equipment.. you have to cover up two ports in the back of the intake manifold.. The hole on the driver's side was fine.. the passenger's side is the one that was open..
Old Feb 27, 2003 | 02:53 PM
anaik's Avatar
[QUOTE]Originally posted by SVT Killer LV
When you put in Hooker Longtubes and !Treehugging Equipment.. you have to cover up two ports in the back of the intake manifold.. The hole on the driver's side was fine.. the passenger's side is the one that was open.. [/QUOTE
If it's the pass. side, there was no vacuum leak.
Old Feb 27, 2003 | 05:12 PM
[QUOTE]Originally posted by anaik
Ditto.
HectorM52
Jul 30, 2017 11:46 AM
BigWil
Mar 29, 2015 12:24 PM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
Catmaigne
Dec 25, 2014 12:16 PM
