egr nessecary or can I remove
Old Feb 6, 2007 | 03:16 PM
46chopped's Avatar
Wink egr nessecary or can I remove
I am removing everthing possible on my 95 lt1 motor can I eliminate the the hole egr system and just make plug off plates - and will it run properly
Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
Old Feb 6, 2007 | 03:23 PM
2000GTP's Avatar
Your emissions may be effected, there may be a possiblility for knock retard and a stumble in the lower rpms, and an SES light may result. Other then that, there is no real detrimental effects on drivability by removing it.
Old Feb 7, 2007 | 04:31 PM
Sweetred95ta's Avatar
If you do it, just have the computer tuned and any side-effects should not be seen.
Boss002
Jan 20, 2016 12:17 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
