EGR help pleaSE
Old Aug 17, 2003 | 10:05 AM
prockbp's Avatar
EGR help pleaSE
i need to change the egr on my '95 Trans AM...
but there's one problem.. i don't know where it is.. i can't see it
does anybody know where it's located?
thx
Old Aug 17, 2003 | 10:09 AM
jbeamj's Avatar
back side of intake manifold on the drivers side of the engine (behind the fuel lines)
Old Aug 17, 2003 | 10:17 AM
AsianSensation's Avatar
EGR location
EGR P/N
Old Aug 17, 2003 | 10:25 AM
prockbp's Avatar
thx guys
Old Aug 17, 2003 | 10:26 AM
predator's Avatar
wing and his pictures
Old Aug 17, 2003 | 10:29 AM
Well...one of the picture belongs to shoebox.
Old Aug 17, 2003 | 10:30 AM
predator's Avatar
thief!
Old Aug 17, 2003 | 10:45 AM
prockbp's Avatar
i can't get a wrench around the driver side nut that is holding this thing on... is there a trick that i'm missing?
Old Aug 17, 2003 | 10:46 AM
predator's Avatar
its 13mm and use the closed end it will go around it
Old Aug 17, 2003 | 10:47 AM
predator's Avatar
also there are 2 nuts on that side make sure you are on the right one there is one that is like 14 mm back there really close to the nut you need to take off just feel around
Old Aug 17, 2003 | 10:52 AM
I took one nut off from the passenger side of the vehicle and the other nut from the driver side of the vehicle. It makes it easier.
Old Aug 17, 2003 | 10:57 AM
EaC95Z28's Avatar
i need to replace my egr valve. i think its getting stuck because the ses light came on and i had it scanned also the light will come on sometimes, then i will turn the car offf and then turn it back on the ses will be off, then sometimes when i will drive it will come on and 5-10 minutes later it will go off. it sseems like the valve is gettting stuck like most of them do. also how much does the egr valve cost and do i just remove those bolts that hold it on and replace it? isn't there a gasket to put on it? also do i replace it from the top of the car or the bottom? it seems pretty hard to get back there! thanks
Old Aug 17, 2003 | 11:02 AM
jbeamj's Avatar
replace it from the top and yes replace the gasket!!!!
now as far as diagnosis goes cant help you there
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
