EGR going bad?
Old Jun 27, 2003 | 10:47 AM
M-MAN's Avatar
EGR going bad?
I could a P0400 code so I know it is the EGR. Question is can I do the EGR block-off mod to stop the code or should I just replace it. It is on a 96 slowmaro z-28. any help please?
Old Jun 27, 2003 | 10:59 AM
jeremyferguson's Avatar
I believe that if you block it off, you will still have a code. I want to take off the egr, air, and evap to get rid of some clutter(plus less stuff that can break), but I am also going to have all of the codes deleted so I don't have the ses light. I've also heard that the egr is one of the causes of the annoying intake manifold leak because the pipe that runs behind the intake manifold gets pretty darn hot, and eventually deteriorates the gasket material.
Old Jun 27, 2003 | 03:48 PM
EviLBoX's Avatar
You'll still get the code if you delete the EGR. To save some money you could try cleaning it, just remove the valve and spray some carb cleaner in the valve.
HectorM52
Jul 30, 2017 11:46 AM
timmy39120
May 8, 2015 11:41 AM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
thenewkid
Nov 18, 2014 12:57 PM
