EGR...discuss
Old Jul 2, 2006 | 08:57 PM
Siamanis's Avatar
EGR...discuss
P0401 - Exhaust Gas Recirculation (EGR) Flow Insufficient
This code is very intermittant.
I get a rough idle when applying vacuum to the EGR so the diaphragm is holding up. Is carbon build up common? I dont ***** foot the lady, as I dont run ***** to the walls. The vacuum lines seem to be ok. Could it be the solenoid? How should I pinpoint?
Old Jul 2, 2006 | 09:07 PM
Re: EGR...discuss
I would check for carbon build up on the valve and ports in the intake.
Old Jul 3, 2006 | 07:33 AM
Blue96z28's Avatar
Re: EGR...discuss
^^Check the links on shoebox's sig, he has an insane write-up on the EGR system....
Old Jul 3, 2006 | 03:49 PM
JohnD's Avatar
Re: EGR...discuss
I have to replace my EGR about every 35K Because it gets carboned up and leaks. Stes that code every time. I'm on the second one.
Old Jul 4, 2006 | 02:42 AM
Compstall's Avatar
Re: EGR...discuss
I'm still using the stocker; I cleaned it up really well inside when I did my cam last year. No problems.
Old Jul 4, 2006 | 07:46 AM
BlackDog's Avatar
Re: EGR...discuss
As long as the egr holds vacuum, there should be no reason to replace the unit. A good cleaning of the egr and intake ports is all that is needed.
