EGR Delete Help
Old Jul 23, 2012 | 08:38 PM
green94maro's Avatar
EGR Delete Help
I got rid of my EGR components on my LT1 but am just wondering what I do with this last thing. It's the EGR solenoid. Do I still need this solenoid to plug the sensor into? And what about the two hoses coming off of it? The one I know I don't need since it's going to the EGR valve, but the other says it's a vacuum feed. What is this and will I need it? Thank you very much guys.
http://shbox.com/1/egr1.jpg
Old Jul 23, 2012 | 10:14 PM
saylorz28's Avatar
Re: EGR Delete Help
chunk it !!!cap it off on the intake... get a tune no prob
Old Jul 23, 2012 | 11:24 PM
Re: EGR Delete Help
So that vacuum feed is okay to cap off on the intake? What exactly does it do?
Old Jul 24, 2012 | 05:27 AM
Re: EGR Delete Help
The EGR valve is operated by vacuum - vacuum opens up the valve. The vacuum is "off" when the solenoid is closed (there is no "sensor" involved). To operate the the EGR valve the PCM pulses the solenoid to provide a controlled vacuum level. Low pulse rate opens the EGR valve a small amount, high pulse rates causes the valve to open more.
Since you have deleted the EGR valve, there is no use for the EGR vacuum solenoid or the vacuum lines. All can be removed, and a small vacuum cap added to the nipple on the intake manifold.
But..... when you unhook the harness connector from the EGR vacuum solenoid, the PCM will set code DTC 27 (appears you have a 94 - why not add a "signature"?) for the incomplete electrical circuit. And since you have no EGR flow at any time, the PCM may also set DTC 32 for lack of flow. You have to have these codes programmed out of the PCM or you will be staring at an SES light.
Just curious - why did you delete EGR? If you have emissions check, you may have a problem with NOx. And you have eliminated a system that can actually prevent detonation (knock) when lugging the engine at low RPM. There is no performance gain, since the EGR system does not operate at WOT or above 3,500 RPM.
Old Jul 24, 2012 | 06:18 AM
Re: EGR Delete Help
I haven't quite gotten around to making a signature yet. But as far as the reason why I deleted it, along with the AIR pump, is just because I ordered long tube headers w/o emissions hookups. I wasn't expecting horsepower gains from this, but I did like the fact that it would clean up the engine bay a little more.
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
tnmotown
Aug 10, 2015 11:52 PM
