EGR block off
Old Jul 28, 2004 | 08:49 PM
JayFoxx's Avatar
EGR block off
Is there any benefit to this?
Old Jul 28, 2004 | 09:17 PM
CamaroZBoy's Avatar
Re: EGR block off
keeps hot gases from getting into your intake, keeping the intake a little cleaner and it can only rob power from you. You wont see any significant gains by blocking it off, but its a good thing to ditch if you dont have emissions. LT1's dont like that smog and bog stuff
Cory
Old Jul 28, 2004 | 09:43 PM
revtime's Avatar
Re: EGR block off
Yep, cleans things up and makes it easier to work on back there. I put in Hooker LTs so I had to ditch the AIR and EGR. I don,t miss em thats for sure.
Old Jul 28, 2004 | 11:12 PM
Re: EGR block off
Who works on stuff at the back of the manifold? The EGR system has more benefits to leaving it in place, than removing it. It does not rob power and only is operational in part throttle situations. It keeps a check on combustion temperatures to prevent detonation, which does rob power and is bad for your engine.
Old Jul 29, 2004 | 12:00 AM
revtime's Avatar
Re: EGR block off
oil pressure sending unit, fuel pressure regulator, trying to get your damn socket on a bellhousing bolt etc
I really have not seen any negative effects from removing it.
I am sure your right (you are rarely if ever wrong) but I aint putting it back on.
Old Jul 29, 2004 | 12:04 AM
Re: EGR block off
If you ditch it because of a header install, I can understand. Otherwise, I say leave it be.
You know, I know what is back there. But is it really a problem that often ?
Old Jul 29, 2004 | 10:13 PM
revtime's Avatar
Re: EGR block off
Well once I figured my fuel problems out ......no I don,t get my hand back in there too often anymore.
I was just so used to older musclecars and sittin in the engine compartment that I have been on a mission to delete anything thats not absolutely needed to keep the car running and it has worked, I don,t mind stickin my hands in there now.
RUENUF
Mar 13, 2016 03:37 PM
marlar98
Oct 21, 2015 02:02 PM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
