EGR+ AIR Pump remove while Headers install Qestn..
Old Jun 17, 2004 | 09:43 PM
ninetythreez's Avatar
Question EGR+ AIR Pump remove while Headers install Qestn..
I got some LT headers I want to install soon. I was wondering about doing away with EGR and A.I.R. at the same time as header installation as I see alot of people do. Will it make a performance gain to remove AIR and EGR?
Can someone give me a link or two to EGR and AIR removal? Thanks!!
Old Jun 17, 2004 | 11:01 PM
MarkyMark's Avatar
no performance gains, but it will clean up your engine bay and you will lose a good 7 pounds or so. Some people say the temps are lower also with them removed. Here is a link, you may wanna try to search the forums for the word egr or air and you will find a bunch of info.
EGR/AIR
Old Jun 18, 2004 | 12:41 AM
dirtybird96's Avatar
I just removed my AIR/EGR with header install. It made so much room in the engine bay. If you do go with the no emission headers I recomend a pcm tune. You should get a performance gain from that
Old Jun 18, 2004 | 08:43 PM
Are there any special tools needed?
Old Jun 18, 2004 | 11:03 PM
Smokn '94 Z's Avatar
Lightbulb
You might wanna have a tubing cutter... I had a real hard time reaching a bolt I could never see that holds a tubing bracket on behind the Power Steering pump so since I figured I didn't need it anymore I used a tubing cutter to cut the AIR tube into pieces and it ended up sliding out of the bracket. That and the EGR just need standard tools and your EGR openings are going to need to be capped. I found some EGR Block off plates from another board member.... This was the best engine cosmetic thing I have done on the engine.. Very easy to access many parts now...
Old Jun 18, 2004 | 11:17 PM
I read where there are 3 bolts holding th AIR Pump and 1 of them gets left in place after the pump removal. Is that the one you couldnt get?
Old Jun 18, 2004 | 11:18 PM
Check this out...lol...Cobra Mustang died..
http://www.slyperformance.com/extra/erikblownup.WMV
Old Jun 18, 2004 | 11:27 PM
Re: .
No. I am talking about the shiny tubing that transfers the air from the pump to the headers.... Their is one that leads to no mans land to get to the passenger side header....
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
tubby
Oct 13, 2003 09:16 AM
CamaroZBoy
Aug 19, 2002 12:41 PM
