Egr ???
Old Jan 2, 2004 | 07:43 PM
94 Polo Z Convertible's Avatar
Question Egr ???
Howdy all,
I've not had time to mess with DTC 32 until now. Taking the rpms to 3000 slowly, I don't see any movement in the bellows of the egr valve. It does stumble when I compress it at idle. The SES light seems to come on when I'm coasting down or idling in traffic. I know there is a separate DTC for the egr solenoid. Is it possible that the solenoid is getting a signal (the scanmaster says it is), but the solenoid isn't sending out info to the valve? If not, then I think my valve is toast. It's really stiff when I compress it, is that normal? The books say that if it stumbles while being compressed that passages are OK. Anybody have any experience with this?
Thanks,
Gabe
Old Jan 4, 2004 | 02:54 PM
If you compress the EGR diaphragm at idle, the engine should stumble or stall. If that does not happen, the passages are clogged or the pintle on the valve is broken or something. Remove the EGR valve and take a look with a mirror.
Old Jan 4, 2004 | 02:59 PM
Hi Rob,
I ordered a new valve yesterday. Probably put it in next weekend and clean the ports at the same time.
Old Jan 4, 2004 | 03:03 PM
If it needs cleaned out, use a screwdriver and a shop vac to keep any debris out of the intake. It's gonna be hard to get to. :/
Old Jan 4, 2004 | 03:10 PM
Thanks, I didn't think about the shop vac. I know it's gonna be a lot of fun, that's partly why I've put off messing with it.
Old Jan 11, 2004 | 06:32 PM
Howdy all,
The new egr valve seems to have fixed it. No codes. I even noticed my gas cap, that I thought was bad, has gotten it's swoosh back when I open it. Once I got the old valve off, with a firm squeeze, it sounds like it has aluminum foil instead of a rubber bellows inside. The ports had a powdery carbon residue that wiped out real easy. She's running like a champ. I didn't realize it had become so sluggish.
Thanks all,
Gabe
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
