Edelbrock LT1 / LT4 Intake
Old Dec 11, 2007 | 10:16 AM
rickreeves1's Avatar
Question Edelbrock LT1 / LT4 Intake
I have a question about using the Edelbrock intake for porting. I read somewhere on here that there may be an advantage to using the Edelbrock LT4 intake over the Edelbrock LT1 intake. Maybe something to do with the runners or how much material can be removed.? Can the Edelbrock LT4 intake be made to fit ported LT1 heads or will it only fit LT4 heads? Anyone have any experience porting these?
Old Dec 11, 2007 | 10:52 AM
Vicious95Z28's Avatar
Ummmm. They are both basically the same casting so what works for one will basically work for the other. No advantage to using the E-LT4 over the E-LT1, same casting.
Old Dec 11, 2007 | 11:44 AM
Z28SORR's Avatar
Originally Posted by Vicious95Z28
Ummmm. They are both the same casting.
Do you know this for a FACT? Just curious, I would assume they are.
The LT4 has a revised rocker cover rail due to the raised intake port opening, on the heads. The LT1 does not have this, so it's possible the there may be some interference here. The machine shop should be able to clearence this area.
Old Dec 11, 2007 | 12:06 PM
The LT4 has a revised rocker cover rail due to the raised intake port opening. The LT1 does not have this, so it's possible the there may be some interference here. The machine shop should be able to clearence this area.
Yep, if you do a search you'll find that they are the same casting, that doesn't mean that Edelbrock doesent "finish" the 2 pieces differently. The E-LTX intakes have been discussed alot here.
Old Dec 11, 2007 | 01:28 PM
v8 FC's Avatar
glad you asked i was thinking about that intake also! not sure which one and if i want to do it
Old Dec 11, 2007 | 02:42 PM
I'd say a good single plane conversion would be a better investment at any level of mods
Old Dec 11, 2007 | 07:23 PM
v8 FC's Avatar
yeah i am trying to get to 400hp on my lt1. i just ordered new heads and i am sending them out to get ported and all that fun stuff. and i was going to get this manifold but i wasn't sure.
Old Dec 11, 2007 | 09:02 PM
96capricemgr's Avatar
Please explain? If you ordered new castings somewhere they you are already off on the wrong foot.
Sounds to me like you are paying too much attention to marketing and not enough to results.
Old Dec 12, 2007 | 01:51 PM
Question
I have not been able to find anything stating that they are they same casting. I may place a call to Edelbrock or maybe one of the forum porters will step in and confirm. If the LT1 and LT4 are the same casting with just a different finishing and someone wanted to have it ported anyway then it would not matter which they chose. Correct? So this would mean that someone could also purchase the LT1 manifold and have it ported and matched to LT4 heads and vice versa with no difference in performance.??
http://www.edelbrock.com/automotive_.../7000/7109.pdf
Old Dec 12, 2007 | 02:21 PM
v8 FC's Avatar
well being that i have cast iron heads in my car i can't port those nor do i want to. so i found a set of used lt1 alum heads and i am sending them out to get ported. do you still think i am paying attention to the marketing and not enough to results
LeftoverChinese
Jan 14, 2024 03:03 PM
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
thenewkid
Nov 27, 2014 09:41 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
