Edelbrock LT1 / LT4 Intake
I have a question about using the Edelbrock intake for porting. I read somewhere on here that there may be an advantage to using the Edelbrock LT4 intake over the Edelbrock LT1 intake. Maybe something to do with the runners or how much material can be removed.? Can the Edelbrock LT4 intake be made to fit ported LT1 heads or will it only fit LT4 heads? Anyone have any experience porting these?
Do you know this for a FACT? Just curious, I would assume they are.
The LT4 has a revised rocker cover rail due to the raised intake port opening, on the heads. The LT1 does not have this, so it's possible the there may be some interference here. The machine shop should be able to clearence this area.
The LT4 has a revised rocker cover rail due to the raised intake port opening. The LT1 does not have this, so it's possible the there may be some interference here. The machine shop should be able to clearence this area.
Please explain? If you ordered new castings somewhere they you are already off on the wrong foot.
Sounds to me like you are paying too much attention to marketing and not enough to results.
http://www.edelbrock.com/automotive_.../7000/7109.pdf
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
