edelbrock headers
Old Oct 1, 2003 | 04:40 PM
blk1994z's Avatar
edelbrock headers
would anyone happen to know the size of bolts i will need for the flages to connect the headers to the y pipe, and to connect them to the heads? I will also need a 3inch flange, can i get that at a local exhaust shop?
Old Oct 1, 2003 | 05:48 PM
Bersaglieri's Avatar
Unhappy Sorry....
Sorry I cant help you there...but maybe a boost to the top can...
Bersaglieri
Old Oct 1, 2003 | 09:33 PM
J's 82's Avatar
email or call edelbrock.. takes them a little while but they do respond.
Old Oct 1, 2003 | 09:40 PM
jasons93z's Avatar
why do you guys respond if your not going to help
Old Oct 1, 2003 | 10:10 PM
JasonK94Z's Avatar
Standard header bolts will attach them to your heads. As for the flange bolts, I would suggest you call Edelbrock. They will be able to answer that without any problems.
Old Oct 1, 2003 | 11:14 PM
jchevy's Avatar
You should just be able to run to the hardware store and get some grade 8 bolts and nuts for the collectors. I assume its just a regular flange, nothing special about it. As for the headers bolts you should be able to use any standard header bolt, most people use ARP's or Stage 8 locking bolts. Depending on how thick the flange is you either want 3/4" long or 1" long bolts.
For my SLP shorties i bought the stage 8 locking bolts. P/N 8911A, they are 1" long.
Stage 8 P/N 8911 are the 3/4" long.
Call edlebrock like suggested above and find out the length you need, then order the bolts, either ARP or Stage 8 depending on which you prefer. Summit sells both. I doubt the ones eldlebrock sells are of the greatest quality.
13qtr
Jul 19, 2015 05:30 PM
Strick
Jul 14, 2015 07:28 AM
mrwz28
Jul 8, 2015 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
