Ed Wright chip
Ed Wright chip
I have an opportunity to pick up an Ed Wright performance chip for my 93 z,automatic. This is if the prom code matches up on my stock chip.The price is really cheap,anyone out there run one of these? I need feedback on how they work. Also will I see a gain(sotp),and do I need a 160 thermo. thanks,Pickerman
As long as the car it came off of had the same transmission as yours and also is a 93 it will work fine.
I wouldn't say SOTP feel.
But I gained .14 on the Gtech.
With the 93s it helps if you manually row the shifter 1-2-3 if you have an automatic. Otherwise the car will still shift at 5700rpm instead of 6100rpm with the chip.
