Ebay stroker short block, what do you think?
http://cgi.ebay.com/ebaymotors/SBC-L...spagenameZWD1V
What do you guys think of that.
I have emailed a couple people that have received them and they seem to be happy. Do you think I could have a budget stroker built locally for cheaper? Can someone give me a ball park estimate on assembly and machining cost?
Re: Ebay stroker short block, what do you think?
How long had the customers you emailed had their engines?
Did they say what kind of set ups & use?
The price is very decent. I've been building a 383 for quite a while and it takes forever to get machine work done in Phoenix.
Machine work should be somewhere between 600 and $1200 depending on if you have the mains splayed. Eagle rotating assemblies are $1500-$1700
If you want cheaper I would do a 355 but you won't be saving a fortune that shortblock is a good price already
A stock crank, Eagle I beams ($250) and SRP forged pistons ($500), $200 rings & bearings. $600 machine work and $400 for assembly and $200 balance is about as cheap as you can go and still have a very strong set up.
im going to talk to some machine shops down here in tucson and see what machining and assembly will cost, If its not to bad i will probably order this
http://cgi.ebay.com/ebaymotors/SBC-L...QQcmdZViewItem
and have it built locally.
The two people I had emailed had only had the motors a couple months, but they had nothing but good things to say.
Im really not worried about getting all forged internals. I never plan on spraying it or any other power adder. Just want it to rev up to 6500 safely
Make sure to give VRE a look....site sponsor and all.
http://web.camaross.com/forums/showthread.php?t=417498
I think they are nicely priced.
If you are not trying to use any power adders then you don't need the forged shortblock. That said, its a good deal so why not get it just in case you change your mind? I've heard good things about those shortblocks by the way.
I emailed them and asked them about just doing a cast steel crank and rods with SRP forged pistons. They said they could do it for ~$2500
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
