Easy q for you lt1 men
Old Aug 17, 2006 | 09:37 PM
Camaro350z28's Avatar
94 maf off a corvette the same on a 97 camaro? my camaro is throwin a code and it dont seem to be the harness so i was gonna try a quick swap if at all possible. Thanks
Old Aug 17, 2006 | 10:03 PM
bingo's Avatar
Re: Easy q for you lt1 men
They are the same.
Old Aug 24, 2006 | 09:31 PM
ShowStopper540's Avatar
idk about all that....93-95 engines were a 'version 1' oif the LT1, the 96 & 97 engines are 'version 2'. They're commonly identified by a vented (96 & 97) or a non-vented (93-95) optispark. I have no idea if that has annnnnything to do with the wiring system on the cars, but maybe it could help.
Old Aug 24, 2006 | 09:36 PM
bingo's Avatar
I am running a MAF from a 97 with my 94 wiring with no problems.
Old Aug 24, 2006 | 09:42 PM
Kevin Blown 95 TA's Avatar
95 optis are vented, not that this has anything to do with the dudes questions. And it's not going to help much if you post unrelated information that happens also to be wrong.
Old Aug 24, 2006 | 09:44 PM
i agree... optispark has nothing to do with the maf... also didnt vented opti start in 95(just to clear the thread up dont want false info in here i started it haha)?
Old Aug 24, 2006 | 09:56 PM
CamaroSS30thAnn's Avatar
i think the maf on my 97 is from a 94-95 car
yes it should work
Old Aug 25, 2006 | 04:34 AM
bowtiepwr's Avatar
>I believe but could be wrong... 1995 had two parts of that year with the Optispark non-vented then vented.
But theMAF should be the same
Old Aug 25, 2006 | 09:41 AM
Bud M's Avatar
p/n is 25008308 for 94-97 LT1 MAF. They are the same.
Old Aug 25, 2006 | 10:33 AM
wrd1972's Avatar
Same
Old Aug 25, 2006 | 09:58 PM
Just to clear this up, we're all right on the 95 opti issue...earlier 95's were non vented, and the laters were ran vented...so its a 50/50 shot to what you run (stock) on a 1995. Non the less, i specifically mentioned i didnt know if this had anything to do with the MAF or not, i just threw the information out there hoping if there WERE any differences, that they may show up and i could save someone his time. At least read it and asses it before you try to correct it.
Old Aug 25, 2006 | 10:13 PM
OK, my mistake then. I have a 95 that I bought in Jan of that year with a vented opti, so maybe there were some 95's built in late 94 with the old setup. Doubt it's 50/50, though.
Old Aug 26, 2006 | 03:39 PM
bowtiepwr's Avatar
>remember the cars usually go on sale around fall time so that means they were in production early summer or late spring.
Old Aug 26, 2006 | 03:48 PM
I guess it only matters for the poor SOBs who bought a 95 and got the previous year's even worse technology...
Old Aug 26, 2006 | 06:21 PM
anaik's Avatar
Where did you get this information? It's the first I've heard of it.
