Easy Horsepower
Old Nov 2, 2006 | 09:38 PM
Joesbod's Avatar
Easy Horsepower
O.k. so my intake manifold gasket is bad on my car. So since i am gonna change it anyway, is there anything I can to do to give me a little horse power boost while I have everything apart?
Old Nov 2, 2006 | 09:52 PM
69gto96z's Avatar
What year and motor?
Old Nov 2, 2006 | 09:57 PM
Joesbod's Avatar
Sorry 94 Z28. LT1
Old Nov 2, 2006 | 09:59 PM
69gto96z's Avatar
U will probably have the valve covers off, so 1.6 roller rockers would be an easy 8 to 10 hp. Maybe an electric waterpump? Those are both very helpful.
Old Nov 3, 2006 | 02:41 AM
2000GTP's Avatar
Although it won't provide massive gains, an airfoil might bump you up a couple of ponies. I like the rocker idea, upgrade your springs as well though.
Old Nov 3, 2006 | 04:59 PM
69gto96z's Avatar
Yeah springs are a must. I would by non self aligning rockers and get some guide plates, this tends to be better than self aligning if you plan on ever revving the motor high, like with a cam swap maybe later on down the road. I have an airfoil on mine, I couldn't really tell any difference, but I know that it probably helped a little.
Old Nov 3, 2006 | 05:08 PM
BUBBA's Avatar
In case you are not aware----lt1 intake leak is normal (and I assume when you say "bad" that you mean you have a leak.) Having said that, if this is the case of the infamous intake leak, be sure to follow the instructions on this board on how to fix the problem---which basically arose because the factory did not put enough sealant to the rear of the manifold.
And yes---a nice addition while under the hood is the addition of 1.6 RRS and springs (be sure to ask more about this crap before you do anything). JMHO
Old Nov 4, 2006 | 01:06 AM
Z95m6's Avatar
Cam!
Old Nov 4, 2006 | 03:53 AM
Heatmaker's Avatar
Advanced Member
Honestly nothing at all really, if all your doing is pulling the intake manifold off.
CARiD
Sep 30, 2015 05:44 AM
Fatdog2
Sep 16, 2015 11:04 PM
NewsBot
Sep 15, 2015 11:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
themex2002
Sep 2, 2015 03:47 PM
