Easiest way to pull the AIR pump?
Old Dec 29, 2008 | 11:45 AM
TBSPW's Avatar
Have to replace mine and im just not sure the easiest way to go about it..
Old Dec 29, 2008 | 12:25 PM
94zgreenmachine's Avatar
Isn't the AIR pump a little electrical gadget on the lower drivers side. Mine was. Are you talking about the AC?
Old Dec 29, 2008 | 03:28 PM
TBSPW's Avatar
nah the air pump for the cats...mine died and i keep getting the check engine light for it so i decided to replace it
Old Dec 29, 2008 | 04:02 PM
Unless it has changed, my 94 had a small ,aprox. 4"x4" , little box. I went to take it off and it fell apart. It should be located on the lower driver side. If I remember right it mounted using holes in the block. I deleted mine about 4 years ago to clean up some clutter.
Old Dec 29, 2008 | 04:27 PM
SnakeOiler's Avatar
Unbolt it from the engine (and unplug the electrical connector), then bolt the new one on and plug it in.
Old Dec 29, 2008 | 05:46 PM
TBSPW's Avatar
alright...thought there might be more to it and didnt want to screw it up
Old Dec 29, 2008 | 07:15 PM
RamAir95TA's Avatar
It's pretty straightforward. Three small bolts, the electrical connection, and the tubes pop right off.
Old Dec 30, 2008 | 12:15 PM
multicar's Avatar
I thought GM had a recall on the '96 air pumps....the dealer should replace it free. I got my recall notice in the mail a while back(yr or 2), but choose not to] since I just rebuilt mine.
Old Dec 30, 2008 | 09:52 PM
TA Dreaming's Avatar
Correct. If the car has not had the recall done on it, GM will fix it for free. I was the third owner of my formula and the light came on the very evening I got the car back into town. I bought it ten hours away. Took it tot he local dealership and they replaced it no questions asked.
Old Dec 30, 2008 | 10:01 PM
TBSPW's Avatar
aiight im surrounded by chevy dealers...how do i go about getting it free...just walk up and be like i heard there was a recall on the air pump and see what they say?
Old Dec 31, 2008 | 09:41 PM
IPrice's Avatar
Yeah....or just call them and give them your VIN so that they can look it up to see if it has been done under warranty already.
-Ivan
Old Jan 1, 2009 | 11:33 PM
TBSPW's Avatar
nice ill pry run down the road to my local chevy dealer tomorrow on the way to work...thanks for the tip guys
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
