Easiest way to drop oil pan ??'s
Old Jul 9, 2005 | 05:23 PM
TA2PLAY's Avatar
Whats the best way to drop the oil pan on the lt1 cars? Will it come out without removing the k member? I need to check out the old oil pump, and any help would be appreciated.
Old Jul 9, 2005 | 09:08 PM
tagz's Avatar
Re: Easiest way to drop oil pan ??'s
The most you can do with the engine in the car is change the oil pan gasket. I did that when i ripped it during my cam in stall. If you can get your hands on an engine hoist, just pull the engine mount bolts and pull it up as far as you can. That may give you enough room, but i never personally did it.
Old Jul 9, 2005 | 09:51 PM
69vette's Avatar
i don't think there is any easy way to get the pan off lol. You have to lift the motor and that still may not be enough clearance. If it was me, i would just support the motor and take out the k member and shock tower bolts and drop the k member down some.
Old Jul 9, 2005 | 10:27 PM
hallbilly's Avatar
take off y pipe, dust cover around the cat if it is an auto, unhook motor mounts and jack the motor up... will be a tight fit but it will come out with some muscle
Old Jul 9, 2005 | 11:33 PM
Lt1t56's Avatar
On automatic cars you can lift the motor and remove the pan. On manual trans cars you can loosen the K member bolts to lower it then jack the motor up and the pan will come out.
Old Jul 10, 2005 | 12:22 PM
ulakovic22's Avatar
That's the way I did mine.
HectorM52
Jul 30, 2017 11:46 AM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
jackpawt883
Feb 26, 2015 09:04 PM
Elcojoe
Nov 17, 2014 10:27 PM
