e waterpump worth it?
It's my DD and I drive the **** out of it in town and otherwise.
Well worth it IMHO
I can't tell you exactly but there are writeups that tell you how to do all sorts of stuff with that.
I have mine on a switch and leds that will light if the pump stops working. It also runs when the ignition is switched to run with the engine off. Or I can switch it off via the toggle switch.
There was posts mentioning a relay system that sets off an audible alarm if there is a fault in the water pump circuit. It might be worth a search. I believe the guy who made them is a member on an Impala board.
colts0455
Sep 2, 2015 12:41 PM
mark0006
Aug 29, 2015 09:45 AM
