Dynoing the Speed Secrets project car..
Old Nov 11, 2005 | 09:45 PM
jimbob65's Avatar
Took my car to the dyno today with 300 miles on the new combo...
Speed Secrets 401
Speed Secrets 4L60E
Strange 12 bolt 3.73 gears
PI 3200 (4100 Stall)
AFR 210's ported by Lloyd Elliot....thanks....
Some tech assit by Bret Bauer....thanks....
448 SAE rwhp/424 SAE rwtq
Here's some video.....
http://www.highspeedproducts.com/video/Jimbo.wmv
Jim
Old Nov 11, 2005 | 09:48 PM
Jameslt1TA's Avatar
Re: Dynoing the Speed Secrets project car..
Awsome numbers and through an auto with a bigger stall.
Old Nov 11, 2005 | 09:50 PM
aarontracy's Avatar
good numbers, nice setup ur working with also.
Old Nov 12, 2005 | 08:30 AM
Quickshotkimber's Avatar
Hyd or sollid?
Old Nov 12, 2005 | 08:48 AM
jimbob65's Avatar
Hyd..
237/245 comp .608/.613
Oh yeah, I used "Howard springs" 175 verified seat pressure at 1.9 installed height and I believe 450ish over the nose "Stock Lifters" at 1/8 turn. Revs to 7100RPM no problem....
Old Nov 12, 2005 | 08:53 AM
Mindgame's Avatar
Congrats, good numbers!
-Mindgame
Old Nov 12, 2005 | 11:28 AM
T/A KID's Avatar
How well do those heads flow, I assume its through a Ported LT4 intake???
I like the cam choice I will have a Very similiar setup, but I will have a 10-bolt (good for dynoing it ) and a converted Super Vic from Bret Bauer. Care to elaborte more on your setup. That thing sounds like a monster, thought about a True duel setup??
Great Numbers BTW
Old Nov 12, 2005 | 02:43 PM
96SilverRam's Avatar
Nice Numbers !
Old Nov 12, 2005 | 03:39 PM
jimbob65's Avatar
Great Numbers BTW
Actually, the manifold is a Speed Secrets special....Welded/Ported and Raised (for more port volume), I can see why Quinn wanted $1500 for his....Lots a work and mula in to it.....
401, 12.5 to 1 compression, 237/245 comp cam .608/.613, AFR 210 heads ported by LE, PI 3200 (4100 stall), 58mm t-body, Hooker LT's, Strange 12 bolt 3.73 gears, Electric water pump, SLP dual dual with 5 inch bullet muffler in line and custom Y-pipe...
Old Nov 12, 2005 | 05:20 PM
SStrokerAce's Avatar
Good numbers!
Old Nov 13, 2005 | 02:37 AM
jimbob65's Avatar
Originally Posted by SStrokerAce
Good numbers!
Thanks....No thank you....
Still think I could get 10 more hp with one of your cams...
Old Nov 13, 2005 | 08:52 AM
A/G's Avatar
A/G
Originally Posted by jimbob65
Hyd..
Kinda shoots holes in what has been considered the pressure limit for OEM lifters.
Old Nov 13, 2005 | 12:02 PM
stew's94z's Avatar
That's what I'm talking about!
Very impressive combination you have there.
Dean
Old Nov 13, 2005 | 03:39 PM
I'd have to look at it but you know me, what you think I'm going to say?
Bret
Old Nov 13, 2005 | 07:57 PM
jimbob65's Avatar
Bret
I would think just going to around 110LSA/108ICL instead of my 114LSA/110ICL would do lots of good....But, it's so damn driveable now, especially with two mufflers inline. That may be a summer project if it's just not quite fast enough! Still got N2O to add yet.....that may be another little reason to stay wider...I am thinking of a bigger MAF now...
Thanks again for tech assit....We'll make it up to ya!
