Dyno this Saturday 11am
Old Oct 23, 2007 | 09:35 PM
z28_theantirice's Avatar
Finally made the call, getting on the dyno this Saturday. Excited and nervous at the same time. Will post video, graph and datalog right away. Shall we take bets on the numbers?
Old Oct 23, 2007 | 10:47 PM
mthegodfather's Avatar
400 is my guess.
Old Oct 23, 2007 | 10:49 PM
kylersaulsbury's Avatar
sounds exciting bro, but i got a quick question. where did you the the caddy lifters, how much, and how do you like them?
Old Oct 24, 2007 | 06:12 AM
CANTONRACER's Avatar
Best of luck.
Old Oct 24, 2007 | 08:32 AM
Z-RATED94's Avatar
Good luck, and yes, keep us posted. Your car an auto, M6, stock rearend? Some more info would be nice, and yeah, my guess will still probably be way off.
Old Oct 24, 2007 | 09:25 AM
ulakovic22's Avatar
415??
Old Oct 24, 2007 | 09:31 AM
96LT1TX's Avatar
I'd guess around 405rwhp/395rwtq
Old Oct 24, 2007 | 05:32 PM
A4 with 3:23's for now, M6 coming this winter
Old Oct 24, 2007 | 05:37 PM
got the lifters from Scoggin Dickie www.spdc.com
They seem like a really great piece for the price, probably a little overkill most likely the ls7 lifters would have been fine but figured why the hell not might as well get some of the best lifters available for the lt1 for pretty cheap.
Old Oct 24, 2007 | 06:29 PM
dangalla's Avatar
382rwhp/370tq is my guess
good luck man, im trying to get on the dyno this winter sometime
Old Oct 27, 2007 | 01:01 PM
I'm back and the cars in one piece there dyno was a Dyno Dynamics put down 370rwhp the guys says he typically sees that this brand of dyno puts down 13% less than a DynoJet with that correction it was 414. Need to do some tuning yet power seems to fall off pretty early, and its running lean the guy said
Old Oct 27, 2007 | 01:23 PM
WS6T3RROR's Avatar
Yikes he wasnt kidding its lean. It needs richened up a tad in the 4-5k rang but after that its off the freakin rails, need to richen it up about 12% or so and get that air fuel ratio down into the mid 12:1 and you'll pick up a good bit of power. Might wanna verify your fuel pressure and log injector duty cycle under max power conditions going down the road, before you adjust your tune.
Old Oct 27, 2007 | 01:29 PM
Yea I was going to bring my fuel pressure gauge but I forgot it, and they didn't have one that fit my fuel rail. I did do some data logs so I can get them posted up.
Old Oct 27, 2007 | 03:07 PM
Link to Datamaster logs
http://www.yousendit.com/transfer.ph...615A0A0FD2161D
Old Oct 27, 2007 | 03:25 PM
mdenz3's Avatar
Which run are the graphs from?
