Dyno #'s with LE2 heads
Old Apr 8, 2007 | 07:46 PM
  #16
speed_demon24's Avatar
Originally Posted by SS MPSTR
for giggles, throw in an OBDI pcm with the exact same tune.
What would be the point of that?
Old Apr 8, 2007 | 08:01 PM
  #17
SStrokerAce's Avatar
Originally Posted by Jon A
I guess it could be valve float, but I would be surprised to see it recover, climb and reach peak power after float has started. Usually, once it starts it's just downhill from there. I really don't know what that looks like--almost like you get 10 degress of knock retard or something, setting it back but allowing it to climb again.
These are new heads and you had the same problem before? Did you use the same springs and are they set up the exact same way? What are the installed spring heights? Did you double check them yourself?
I hope you get it figured out as it seems like an odd problem and I'd be curious to find out the cause. Once you get it straightened out you'll have a real monster it looks like.
Exactly, if it's a valvetrain problem it usually doesn't recover unless it'sa odd resonance, which the beehives don't have one major resonance so I would feel safe to rule that out.
Bret
Old Apr 8, 2007 | 08:10 PM
  #18
SS MPSTR's Avatar
I had the same issue and a change to the earlier PCM solved it.
Old Apr 8, 2007 | 10:20 PM
  #19
96 mikez28's Avatar
Originally Posted by blazzen
Hey I had the same problem with my set up le2 heads le1 cam made 397 hp 367 tq on a mustang dyno.
Very nice #'s on a MD
Old Apr 9, 2007 | 08:21 AM
  #20
METALBEAST's Avatar
Nice numbers. Are u running the LE2 cam?
Old Apr 9, 2007 | 08:30 AM
  #21
It's a custom cam from Bret, I got it back when I had my old heads. Its between an LE1 and LE2 in size. Its in the same ballpark as the 503/ gm 846, CC305, ect to give you an idea of how it is by size.
Old Apr 9, 2007 | 08:37 AM
  #22
Well I'm gonna try adjusting the rockers with the motor running and see if that helps at all, maybe I didn't find 0 lash very good with the motor off, + it was sitting for a couple months so I'm sure a few of the lifters bled down by then.
Old Apr 9, 2007 | 09:34 AM
  #23
Javier97Z28's Avatar
Moderator
I don't think that's going to fix your problem if you had that issue before.. y'know? Doubt you had the same misadjustment twice.
Old Apr 9, 2007 | 02:17 PM
  #24
T/A lt1's Avatar
Nice gain, Lloyd does realy nice work on these LT1 heads. Just and FYI guys I saw 2 smallblock Mustangs down at a local dyno. One made 355rwhp on a Mustang dyno and has been 10.20's@128mph, the other 310rwhp, 10.60's@124mph. Both cars are lightweight coupes and have loose converters but it shows what you can do with a little horsepower and the right setup. Later Clint
Old Apr 9, 2007 | 03:07 PM
  #25
reamo04's Avatar
yeah, if only our cars weighed as little as mustangs
id love to transplant my motor into something lighter
ie. fiero, 240, 300zx, rx7.....the idea keeps sounding good, but the checkbook doesnt always agree
Old Apr 11, 2007 | 04:48 PM
  #26
Well I took my opti apart and it was acring inside of it, so 405rwhp with a bad opti isn't bad.
Old Apr 11, 2007 | 06:47 PM
  #27
turbo_Z's Avatar
If your opti was dropping spark completely then the ARF on the dyno graph woulda showed it... I didnt see any sudden changes. My guess is lost timing rather than lost spark but good luck. Did you get a new GM opti?
Old Apr 11, 2007 | 06:56 PM
  #28
Ordered an MSD cap/rotor. I was getting dyno tuned so he adjusted the a/f, I'll have to throw it back on the dyno with the new opti to make sure the a/f is good.
Old Apr 12, 2007 | 05:20 AM
  #29
Jon A's Avatar
I hope that fixes the problem. Let us know how it turns out.
Old Apr 12, 2007 | 05:27 PM
  #30
SS RRR's Avatar
The highest I dyno'd before the heads was 375rwhp, the baseline I put down yesterday was 391rwhp, then I ended up with 405rwhp. So I gained 30rwhp over my old heads before I sent them to Lloyd, and I gained 14rwhp over the baseline I put down on my old tune for the old heads.
That's crazy... running 118mph w/ 375rwhp. W/ that gain you should see some massive mph gains through the 1/4. I would venture to say 120+mph.
How much does your car weigh?
