Dyno numbers with new setup..Joe O Cam, LE1 Heads
Old May 9, 2006 | 08:56 PM
96trans am's Avatar
Finally done my heads/cam setup. I installed LE1 heads with 918 springs, CC OEM Lifters, CC pushrods, CC 1.6 Pro-mags. Joe O Cam. 22x 23x 110LSA. Ive heard this cam referred to as his "small but nasty" cam. Meziere Electric Waterpump, New Opti, Cloyes Double Roller Timing Set, Ford 30# inj., 52mm TB, Pacesetter LT's, Pacesetter Offroad Y-Pipe. Already had SLP Loudmouth installed. After Dyno Tuning the car I put down 385rwhp 367 torque
Old May 9, 2006 | 08:59 PM
marshall93z's Avatar
Re: Dyno numbers with new setup..Joe O Cam, LE1 Heads
Nice!!
Old May 9, 2006 | 09:30 PM
Z-RATED94's Avatar
Nice. Is this on a stock bottom end?
Old May 9, 2006 | 10:09 PM
91RSLT1's Avatar
Nice! Auto or 6-speed?
Old May 10, 2006 | 01:34 AM
HardcoreRM125's Avatar
Im gonna step out on a limp and say most likely a 6 speed. I think that cam is right around a BRE LE1 cam power levels, and those numbers are pretty close to a LE1 package ...
Old May 10, 2006 | 05:32 AM
96trans am's Avatar
M6 stock bottom end. Moser 12 bolt w/ 4:11's.
Old May 10, 2006 | 06:26 AM
NightTrain66's Avatar
good #'s for a small cam.
That rear end isn't helping the dyno #'s any but at least you can launch with out picking up pieces.
I am sure it is fun to drive.
Lloyd
Old May 10, 2006 | 08:09 AM
LT4POWR's Avatar
good #s
Old May 10, 2006 | 09:53 AM
scrmnws6's Avatar
Very nice #'s. Now take her to the track and post those #'s.
Old May 10, 2006 | 10:22 AM
ABA383's Avatar
I think I have the same cam (I'll PM you the specs) but mine's on a 111...I put down similar power last year with shorties ( I'm also a 383). Thats a great cam and I went 118mph with it last year...Which dyno? I see you are around my neck of the woods (where I work). Will probably go 120mph with it since I've gotten the stpped Kooks and EWP now...Take care...
--Alan
Old May 10, 2006 | 10:39 AM
SStrokerAce's Avatar
FWIW Handyman's Impala has a LE1 cam, but LE2 heads.
Nice numbers man, should be like driving a stock car around with just a lot more power.
Bret
Old May 10, 2006 | 10:46 AM
Z-RATED94's Avatar
Bret
That's the thing about these small cams and LE heads. They make nice HP and drive damn near like their stock.
Old May 10, 2006 | 02:27 PM
96trans am's Avatar
I wouldnt say minees like driving a stock car but I blame that mainly on my spec stage 3 clutch that is near impossible to slip. Its more of an ON/OFF clutch then any other clutch I have experienced. The cam has a pretty mean lope to it as well.
Old May 10, 2006 | 02:38 PM
LT14LIFE's Avatar
Nice numbers, especially for stage 1 heads and a "small" Joe O cam and thru a 12 bolt..You'd be close to 400 thru a 10 bolt..Nice!
Old May 10, 2006 | 03:39 PM
hsyr's Avatar
The clutch must be new because after a few miles they break in and are not that bad to drive. I dd a stage IV, I love it, although spec makes crappy clutches and it will be the last one I buy.
