Dyno HELP!!! SHEET ATTACHED
Old Dec 30, 2003 | 09:18 AM
NJCustoms's Avatar
Unhappy Dyno HELP!!! SHEET ATTACHED
It was breaking up bad. I'm sorry it took so long to get the dam sheet scanned. But here you go! Plugs, wires, fuel filter etc all done about 4k ago.. Is it knock sensor or Opti? Maybe fuel??? EXPERTS PLEASE TAKE A LOOK
Try this one too...Other Link
Old Dec 30, 2003 | 09:35 AM
stereomandan's Avatar
The link won't show me the picture.
Dan
Old Dec 30, 2003 | 09:58 AM
NJCustoms's Avatar
i added another link it should work now.
Old Dec 30, 2003 | 10:31 AM
drewstealth's Avatar
Looks like the car is missing pretty bad. I would check your plugs and wires first. Also when was the last time you changed your fuel filter? I also noticed in your sig that it didn't mention a LT4 KM. If you don't have one of those you are more and likely gonna be seeing a lot of false knock with those LT's and Loudmouth. So if you don't have one then you definatly need to get one. Other then that it could also be your opti. But i would try the other options first.
Old Dec 30, 2003 | 10:54 AM
NJCustoms's Avatar
Plugs, wires, coil, Ing module, fuel filter, injectors cleaned. 4051 miles ago..
It felt and sound like it was tagging the rev limiter...
Old Dec 30, 2003 | 10:56 AM
Do you have a lt4 knock module or not?
Old Dec 30, 2003 | 10:58 AM
got_hp?'s Avatar
Re: Dyno HELP!!! SHEET ATTACHED
Originally posted by NJCustoms
Opti?
that would be my guess.
Old Dec 30, 2003 | 12:18 PM
NJCustoms's Avatar
Would the Opti just be failing up high like that??
Old Dec 30, 2003 | 12:41 PM
The opti can make your car act many different ways when its going out. The graph looks like it is breaking up a bit the whole way but it drops real bad in the higher rpms. But do you have a LT4 knock module or not?
Old Dec 30, 2003 | 12:44 PM
NJCustoms's Avatar
No LT-4 Knock module. I scan the computer but it did not throw a single code...
Old Dec 30, 2003 | 12:47 PM
FastWhiteTA's Avatar
Him not having an LT4 KM won't cause his car to miss that much. It's gotta be the Opti spark man. An LT4 will help, but that won't fix your problem.
Old Dec 30, 2003 | 01:17 PM
It can if he is seeing a lot of knock. It would pull a lot of timing. Also if was his opti and it was missing that bad it would throw a code. This doesn't mean it can't be his opti because it still can be but i would try the lt4 km first.
Old Dec 30, 2003 | 01:46 PM
crAzy95z28's Avatar
ge ta DYNASPARK
Old Dec 30, 2003 | 01:59 PM
97Camaro007's Avatar
The opti can act like that.....Did you get a print out of Air/Fuel? Might want to see what's happening there also....I had a fuel pump that was on the way out and was doing something like this also......
Old Dec 30, 2003 | 02:08 PM
NJCustoms's Avatar
I didn't get the air fuel print out, but alas all was well there. I am giving serious thought to the LS1 coil in spark setup with the use of MSD crank trigger.
