Dummy Light ?
Old Apr 9, 2003 | 03:32 PM
Black_Z28's Avatar
Dummy Light ?
I have a problem with my dummy lights. WHile I was driving home today four of them came on for no apparent reason. It was the INOP ABS, Brake, Low Traction, and the ASR Off. The brake and the low traction one would flicker on and off. But the other two just stayed on. The car runs the same as before. Any of you guys have an idea. I thought about pulling the battery for a moment and see if that helps. But after that I don't know what to do. Any advice would be good. Thanks.
Old Apr 9, 2003 | 04:00 PM
Most of the time that is caused by low voltage. Did you happen to notice the volt gauge? Make sure your alt is charging and you have no loose battery connections.
Old Apr 9, 2003 | 04:31 PM
Black_Z28's Avatar
Well, I did just take the car out of storage yesterday. But I did charge the battery before I installed it. I noticed the Voltage gauge bounce up and down, but that was during the flashing of the E-Brake light and low traction lights. I did move just a little bit. Just a couple of mm in both direction.
Old Apr 10, 2003 | 02:13 PM
Black_Z28's Avatar
Could it be a speed sensor??
TTT
Old Apr 10, 2003 | 02:42 PM
z28Power's Avatar
Still sounds like a voltage issue. Make sure all the wires from battery are secure, and wiring to alternator is secure as well. Take a voltmeter and read the power you are getting off of the battery and alt. when the car is on/off Just to see.
Old Apr 10, 2003 | 03:12 PM
Black_Z28's Avatar
My friend has a scanner, so I'm going to try that this weekend. I hope it tells me what's wrong. Stupid lights annoy me.
dluna333
15
Mar 13, 2015 12:30 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
