Dumb Warped Rotors!
Old Mar 17, 2003 | 11:14 AM
TToP's Avatar
Dumb Warped Rotors!
Any suggestions with what to replace them with? Don't wanna spend a ton of $$$, but would like to go with something slotted or cross drilled. (Not for the supposed performance benefits, but for looks) Depending on what your opinion is on Drilled. I hear alot of BS about them cracking ALL the time. My fronts were warped last year. Got them turned, and everything was good for about 6 months, but I feel it happening again. Just going to replace them this time, as I'm sure i can't cut them again here now. They'll be below spec for sure. Also wanted to replace brake hoses to the braided ones, and replace fluid as well. Haynes manual says NOT to bleed the brakes yourself because of the ABS ****e. Has onyone done this to there brakes, and if so are there instructions or a how to anywhere on how to do this properly? Breaks scare me a bit, and I just want to be able to do this myself, as well as right the first time! Rotors I was looking at .... EBAY LINK
Old Mar 17, 2003 | 11:36 AM
Larnach's Avatar
What's your budget?
Old Mar 17, 2003 | 11:40 AM
TToP's Avatar
Couple hundred bux should do. I'd like to do all 4 especially if I go slotted. But it's just the fronts that are warped. As far as I know.
93 RedBird
Nov 15, 2015 08:24 AM
HibachiZ28
Nov 6, 2015 12:53 AM
jayblev95
Sep 26, 2015 09:44 PM
Henson071
Sep 18, 2015 04:01 PM
surreybrad
Jul 29, 2015 02:55 PM
