Dual spring vs beehive spring
Old Jun 16, 2007 | 08:42 PM
95fbformula's Avatar
which would be the best for a 12 to 1 compression 355 reving to 6800-7k.
I am between the crane 99893s dual spring
1.460" outside diameter
130 pounds seat pressure
402 pounds open pressure @ 1.150"
Set of 16
or the pac 1218s beehives
seat 130 @ 1.800/ Open 318 @ 1.200
Old Jun 17, 2007 | 10:32 AM
stereomandan's Avatar
Depends on cam lobe. What cam?
Dan
Old Jun 18, 2007 | 06:12 PM
SStrokerAce's Avatar
Beehives, hands down. Do a search using my name and the term beehives if you need a good education on them.
Bret
Old Jun 18, 2007 | 09:36 PM
Bret
Will do, I am pretty much settled on the pac 1218s or 1518s, possibley the 1220s and have my heads machined to fit.
Old Jun 19, 2007 | 12:33 PM
You have to do more than open the spring pockets for the 1220's, you need longer valves as well. The 1218's will work just fine.
Bret
Noenav
Mar 1, 2019 07:38 AM
Drtryder
Apr 22, 2015 04:17 PM
95chwagon
Jan 13, 2015 09:19 PM
