DTC 42 after LE2 Head and Cam swap
Old Oct 15, 2009 | 08:22 PM
ptown's Avatar
Im getting code 42 after a head and cam swap. Car starts and runs fine. Could I have missed a ground wire? I also have the delteq ignition. I will check the wires tomorrow. I have missplaced my camaro manual. Should I take out the pcm and make sure all the connections are tight? Has anyone had to replace the opti for this?
Old Oct 16, 2009 | 05:51 AM
ptown's Avatar
Sorry about the duplicate post. I tried to delete the other one and it is still there.
Old Oct 17, 2009 | 04:56 PM
ptown's Avatar
Ok I know DTC 42 is the ignition control signal from the PCM to ICM that fires the ignition. I pulled out the pcm and pulled the black labled wires out. I checked all of my connections on the delteq. Could it be the pcm itself is bad. I swapped mine for one from pcm4less. Any help would be appreciated.
Old Oct 18, 2009 | 04:56 AM
ptown's Avatar
Does anybody have any ideas on this? I have done a search and I dont see any solutions to this.
Old Oct 18, 2009 | 08:40 AM
Guest47904's Avatar
Guest
False code
You must have found a history code not an active code since a 42 would have shut off the injectors.
A 42 indicates the IC signal (white wire from the black PCM connector pin 5) to the ICM. In this case the Delteq ICM, is at or near ground potential.
So either the wire has an intermittent short to ground. Or the Delteq ICM is questionable.
Simply reset the code and watch for either the engine to shut down or code to return. Then you know what to check.
Old Oct 18, 2009 | 12:10 PM
ptown's Avatar
Ok I reset the code and it comes back about 10 seconds after I start the engine up. So does that mean the delteq icm is questionable?
Old Oct 19, 2009 | 05:37 AM
Guest47904's Avatar
Guest
I wouldn't think so. According to the book, a 42 shuts off the injectors. So if the engine continues to run, the only reason I can think of is the white wire must be touching ground intermittently.
Disconnect one end of the white wire and ohm it to ground. With the meter attached, wiggle the wire from one end to the other and see if it ever reads at or near 0.
Old Oct 20, 2009 | 06:39 AM
ptown's Avatar
I will check it out this weekend. Thanks for the advice speedy
chuyz28
Feb 19, 2015 12:50 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
Queens94z28
Nov 20, 2014 06:03 PM
