driveshaft wobble
Old Jun 9, 2003 | 09:29 PM
jeff1586's Avatar
driveshaft wobble
i have the stock steel driveshaft in my 95 lt1, at it wobbles really bad on the highyway at about 90, does it hurt to take it the the 1/4. i have ran it once and taken it up to 102, but it wobbles bad, should i buy an aluminum one before i take it to the strip again
Old Jun 9, 2003 | 09:55 PM
CamaroBoy96Z28's Avatar
Re: driveshaft wobble
All stock steel shafts do that. I run fine with mine. You can get a balanced LS1 or 1LE driveshaft but IMO its not worth it. Plenty of guys still run their stock steel shaft. If you do decide to go Al, get the 1LE, its supposed to be stronger than the LS1 shaft which is more prone to being twisted up. For the "gain" if any, I say stick to your stock shaft.
RUENUF
Mar 13, 2016 03:37 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
LazyLemming
Aug 29, 2015 07:36 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
