driveshaft vibration
Old Aug 13, 2003 | 05:21 PM
PROJEKT Z28's Avatar
I did a search and all it did was add to my confusion-
I had my transmission rebuilt and under heavy throttle there is some serious vibration. I suspect the driveshaft- I asked the mechanic if he was sure the driveshaft was installed the same way it was, and he said that doesn't matter.
How do I "rotate the ds 180 degrees"?
Does this mean that I take the whole ds loose, and switch the transmission end to the differential end? Is this possible?
Or do I simply take it loose at the transmission, and rotate the ds 180 degress, and re-bolt it? (How does this have any effect if the ds spins 360?)
Old Aug 13, 2003 | 06:11 PM
OldSStroker's Avatar
Re: driveshaft vibration
Rotaing 180 degrees means disconnecting it at the rear end, where it is attached by 2 u-bolts, turning it 1/2 turn and reattaching the u-bolts. Torque them properly. Sorry I don't have the manual here, but I can look up the torque spec tomorrow if you need it. PM me.
It can matter. Some folks mark the u-joint/rear end flange position before they remove a driveshaft.
It shouldn't make any difference, but since all parts are not perfect, it could have gotten very "comfortable" the way it has run with the mating parts.
A u-joint could be going bad, or a trans mount. I'm surprised the mechanic didn't check that kind of thing...no, I'm really not.
Old Aug 14, 2003 | 10:29 AM
Thumbs up
Thanks- I will rotate the shaft when I install a ds loop next week.
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
realistyc
Jul 28, 2015 07:32 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
