Drivers side Head
Old Oct 28, 2007 | 02:24 PM
lt1loudmouth07
Guest
Posts: n/a
Drivers side Head
Well i have 2 bolts broken off in my cylinder head to where nothing is sticking out where i can get them out my headers are leaking really bad. My question is how hard is it to change out the cylinder head on the driver side can someone point me in the right direction of what i need to do
Old Oct 28, 2007 | 02:41 PM
MeanGreen97Z's Avatar
The drivers side head is the easy one.... how many miles on this motor?
Old Oct 28, 2007 | 02:48 PM
lt1loudmouth07
Guest
Posts: n/a
miles
94000 if i do this can i leave the exhaust manafold on
Old Oct 28, 2007 | 03:48 PM
Mtxz453's Avatar
ha im in the same predicament that you are in with my longtubes, ill be taking my cylinder head off this weekend to put some time-serts in.
Old Oct 28, 2007 | 08:11 PM
lt1loudmouth07
Guest
Posts: n/a
head
I was wondering how hard it is to take the driver side head off a 95 camaro z28 i broke two header bolts inside and none are sticking out to where i cant get them out. Would i have to take the intake manafold out to do this or could i just leave it on there its just the driverside i want to just swap the head out with a stock one please let me know.
Old Oct 28, 2007 | 08:34 PM
Its relatively straight forward. You will have to pull the intake manifold. Good thing is you can leave everything on it. Going to have to remove some of the stuff on the front of the motor like the water pump but it's all easy to do if you are mechanically inclined.
Old Oct 28, 2007 | 08:48 PM
Stl94LT1's Avatar
The water pump doesn't need to come off to pull the head.
Old Oct 28, 2007 | 09:24 PM
Are you sure? Could have swore there was an accy bracket.... maybe it's to take the passenger side head off.... Hell it's been a while.
Old Oct 28, 2007 | 09:33 PM
Stl94LT1's Avatar
The water pump isn't connected to an accy bracket.
karnykamaro
Feb 2, 2015 01:37 PM
ModdedNerd
Jan 29, 2015 07:23 PM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
