double roller timing set on 96-97
Old Jun 18, 2003 | 11:01 PM
QCKZ28's Avatar
when i decided to switch to a double roller for the extra insurance
i thought no big deal just switch to an electric wp. well there much more to it on 96-97 models. we have the crank position sensor. heres what ive had to do just to run it
1. electric wp
2. pull water pump drive gear out of block (really easy)
3. grind the front cover to make it fit
4. grind the CPS down
5. reluctor ring wont fit under the cover, had to buy a pre 96 hub that is a little bit longer
6. reprogram the CPS out of the pcm (not necessary)
i think thats it, not sure though
jesse
Old Jun 18, 2003 | 11:17 PM
Buttercup's Avatar
Believe it or not there have been a few people that have made custom CPS setups that work with double rollers. If you have to deal with the new OBDII emissions tests you must have the CPS system active. Sorry I don't recall the specifics
Old Jun 18, 2003 | 11:22 PM
QCKZ28's Avatar
no emissions here thank god
Old Mar 12, 2004 | 05:01 PM
blown383's Avatar
Where can I order a 94-95 hub?
Old Mar 13, 2004 | 05:03 AM
QCKZ28's Avatar
www.thunderracing.com
Old Mar 13, 2004 | 05:53 AM
97WS6SCharged's Avatar
What kind/brand of timing chain did you use?
Old Mar 13, 2004 | 06:54 AM
30thannZ28's Avatar
I trust it wasn't cloyes.
Old Mar 13, 2004 | 03:43 PM
blown383's Avatar
Thanks for the info! Anything else I need to know?
-B
Old Mar 13, 2004 | 10:09 PM
30thannZ28's Avatar
I wanted to know what timing set you used. was it cloyes?
Old Mar 13, 2004 | 11:56 PM
I wonder if it's possible to grind down the reluctor ring to make it into a spacer? Anyone else have any good info for doing this that doesn't involve switching to a pre 96 hub?
Old Mar 14, 2004 | 12:01 AM
I don't remember anyone mentioning a reluctor problem before. Maybe my memory is going? If the thickness of the new crank gear is the same as the stock piece, there should not be a problem.
Old Mar 14, 2004 | 12:03 AM
That's what I'm thinking, but I haven't had a chance to work on my car for a week now. I'm definately going to double check in the morning/afternoon when I leave work.
Goal for tomorrow, get the heads/intake on the freakin car.
Old Mar 16, 2004 | 06:22 AM
30thannZ28's Avatar
can any other cloyes double roller users confirm this clearance issue? I've never heard of the cloyes kit giving any problems.
Old Mar 17, 2004 | 09:04 PM
Yeah, I had to clearance my timing cover. It's not the gear that made contact, it was the chain. I just took a paddle wheel and ground down the area where the crank seal goes. I'll post some pics I took to show the difference between the old gear and the new gear.
Old Mar 17, 2004 | 09:11 PM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
But he's running a double roller. So.. it's twice as thick and the stock gear. Literally..
