Double roller timing chain install
Old Sep 1, 2003 | 05:27 PM
magnumv8's Avatar
when installing a double roller timing chain you have to remove the water pump drive gear right? If so how do you get it off.
Old Sep 1, 2003 | 07:15 PM
atljar's Avatar
Take off the old timing chain.
Undo the retainer plate holding the gear in place, and pull it out. If the intake man is off you can knock it out from the back. It may need some persuasion (sp?) ie vice grips.
Old Sep 1, 2003 | 09:16 PM
magnumv8's Avatar
OK thanks. One of the online install guides I found said to use some GM tool, so I just wanted to make sure before I pounded it out.
Old Sep 1, 2003 | 09:35 PM
Transamdriver's Avatar
I just used the claw end of a hammer and stuck it behind the gear and it popped right out.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
