Double Roller on a 93 LT1
Old Feb 17, 2006 | 05:47 PM
aboatguy's Avatar
Will a Cloyes Timing Chain set [CL-3145 ] fit on a 93 LT1 with an electric water pump with the original timing cover?
I know that it will work on my 95 however, a friend wants to install a double roller on his 93.
Mike
Old Feb 17, 2006 | 06:29 PM
lillbush5555's Avatar
Re: Double Roller on a 93 LT1
Should be the same. I bought a 93 motor with one so I assume it works.
Matt
Old Feb 17, 2006 | 07:19 PM
Demon's Camaro's Avatar
No it will not. 93-94 got shafted. You have to get a 95 timing cover only, then all the gaskets and what not.
Old Feb 17, 2006 | 07:36 PM
aboatguy's Avatar
That is what I thought! Any one else??
Old Feb 18, 2006 | 08:43 AM
RunRiot's Avatar
In addition to the 95 timing cover, it needs to be converted to a 95+ Opti, including a new piece of wiring harness and a longer pin for the cam. And the early LT1 cams (including aftermarket) didn't have a hole big/deep enough for the 95+ Opti guide shaft, so it may need to be drilled. Don't try doing this with it installed, I did this and got slightly off-center, which shook the Opti to death within 200 miles. Later all aftermarket LT1 cams came with the bigger hole and longer pin.
Old Feb 18, 2006 | 08:52 AM
Javier97Z28's Avatar
Moderator
You'll need to swap cams, sorry, no way around it.
nikolt1
Feb 27, 2015 09:10 PM
Queens94z28
Dec 20, 2014 09:11 PM
97 RedSS
Jun 10, 2003 07:58 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
IDOXLR8
Aug 6, 2002 12:30 PM
