Doors won't stay LOCKED
My doors won't stay locked. It seems to be happening around every five minutes they'll unlock themselves, even if the door is already unlocked they'll lock themselves then turn around and unlock themselves. Another thing I noticed, now when I turn my car off the doors will unlock, it use to not do this untill the other problem started. What could be the problem? Please help, I don't want to find my car stolen because of this.
I have heard of others complain of this. I don't really recall what the fix was, but I would think it has something to do with the keyless entry receiver. Maybe it is getting some moisture in it.
same exact thing happened to me, i am not exactly sure what caused it, but shortly after i washed my car it happened, it could of been water, so what i did is put my heat on high and drive around for about an hour (BCM is near heat outlets i think), and it went away. i havent done anything to prevent it from happening again since it has been rained/ washed so much and it didnt do it again. Maybe it's just a 94 thing?
This has happened to me two or three times...always when i showed up at work too. Anyway, I just disconnected the battery, came out of work like 6 hours later, reconnected it, and it worked fine. Solved it every time.
