Done With Engine Build - Leftover Gaskets.. AHH (Pic)
Old Jul 27, 2008 | 01:13 AM
ENRKyle20's Avatar
here is what I have left from my gasket set. Its quite alot.. the brown one that is almost centered I got with my intake manifold gasket set.. no idea what its for.... and the 2 round ones?.. i dono somehting with the oil filter thing?. I didnt see ne where for it tho?. I already put a new one on there. the big round one I got with my rear main set. It had the half gasket and I used that, but I didnt see a place for that. Any advise on any of them.. hmm.
the picture is large so here is a link.
ftp://test1:test11@web171.ixwebhosti...ff/Gaskets.jpg
Old Jul 27, 2008 | 08:42 AM
Don 97 SS's Avatar
From my recollection the far left one is the seal for the WP drive and the one on the right is WP related.
Old Jul 27, 2008 | 09:51 AM
Stl94LT1's Avatar
The one on the left looks like the early opti seal, and the big O-Rings are for the oil filter adapter.
Old Jul 27, 2008 | 11:11 AM
ENRKyle20's Avatar
Thank you both for your help.
So, we got a sure thing on the far left not being for my vehicle. thats good. I was most worried about that one.
(I know about the waterpump drive, but I already replaced all three seals in my timing cover so I dont think it was for that since it didnt fit)
I dont see where the large rubber ones go on the oil filter adapter. I put a paper gasket under oil filter adapter, one rubber gasket under the cooler. thats the only 2 that my book points out for it and I dont see where any more would go.
The one on the right came with my rear main seal kit (with the rear main, and the main carrier to block gasket) I got it seperatly at autozone after I forgot to put the alignment dowel under it so my original gasket was toast after i had to takeit back off. but my original gasket kit didnt have this. so I dont think I need it.
I have no idea yet what the little white one is, or the brown one next to it (that came with my intake manifold gasket set.
Old Aug 1, 2008 | 12:17 AM
ENRKyle20's Avatar
well. I guess I will know when I start it tommrow. I got themotor in the car, just need to hook up fuel and wiring.
Old Aug 1, 2008 | 09:42 AM
kylersaulsbury's Avatar
i would say your fine, the others are probably for oil filter adapters on roadmasters or something. i had about the same pile laying around when i got done.
Old Aug 1, 2008 | 05:47 PM
ENRKyle20's Avatar
looks good, no leaks.. fired right up.. Must have been extras.. You can see the video in the LT1 section under "Fisrt Startup Video"
oldschool
Feb 9, 2016 09:21 PM
Jrlt1
Jan 3, 2015 07:38 PM
BillyBobVA
Sep 10, 2002 06:06 PM
squirrels
Jul 13, 2002 01:58 AM
