Doing hotcam kit, what gaskets.
Old May 8, 2004 | 02:12 PM
WrecklessZ's Avatar
Intake, valve cover what am I leaving out?
Old May 8, 2004 | 02:17 PM
madwolf's Avatar
If the intake kit doesn't come with a TB gasket, I'd get one. Don't forget high temp RTV if the kit doesn't come with it. Replacing the injector o-rings would also be nice. (My Fel-pro intake kit came with both RTV and o-rings)
Timing cover gasket.
Timing cover seals. (crank/opti/waterpump)
2 waterpump gaskets.
If you brake the oil pan gasket while taking the timing cover off, you will need one of these as well.
Old May 8, 2004 | 07:41 PM
WrecklessZ's Avatar
Any summit part numbers???
Old May 8, 2004 | 08:34 PM
gb95zconv's Avatar
Re: Doing hotcam kit, what gaskets.
Water pump gaskets, o-rings for opti shaft.
Old May 8, 2004 | 09:28 PM
94DROPTOPZ28's Avatar
I just did this on my car last week & Madwolf has it exactly right:
Intake Gaskets
Valve cover gaskets
Waterpump gaskets
Timing cover gasket & seals (crank/opti/ waterpump)
Oil pan gasket if you happen to tear it
I used "Great stuff" instead of RTV it worked much better
And be VERY carefull with the waterpump driveshaft seal it tears very easy!
I used a 1/2" socket and covered it in oil and slid the seal onto it & then used a bigger socket and a rubber mallet to put it into place and it worked great and it didn't tear...
lt1xondeck
Mar 18, 2016 07:22 PM
CARiD
Jul 7, 2015 08:19 AM
WildRidez
Jan 16, 2015 03:10 PM
T/A lt1
Oct 10, 2002 03:14 PM
T/A lt1
Sep 5, 2002 06:53 PM
