Does this wear look normal? (PIC)
Old Apr 28, 2003 | 11:29 PM
PoorMan's Avatar
Just wanted to get some replies from some of the experienced people here that have done engine rebuilds, ect. Below is a pic of my stock head at 74k miles right after I took it off. Does it look like normal wear? Not sure what any of the signs would be if something may need attention. Both heads look pretty much the same as far as color, carbon build up, ect.
http://community.webshots.com/photo/...70680366PTKPNg
Jeff D.
Old Apr 28, 2003 | 11:57 PM
94 CAMRO Z28's Avatar
I dont have a ton of experience myself, but from what I can tell that looks pretty good.
Aaron
Old Apr 28, 2003 | 11:58 PM
chasmanz28's Avatar
Aaron
they look damn good, for 74k on them
Old Apr 29, 2003 | 07:51 AM
PoorMan's Avatar
thx for the reply guys.
Jeff D.\
Old Apr 29, 2003 | 08:37 AM
grygst76's Avatar
I pulled mine @90,000 and they looked similiar to that pic--that looks decent for the miles!!
Old Apr 29, 2003 | 10:35 AM
All_Z_Way's Avatar
I just pulled mine at 63k and they looked very similiar. Mine may have been a little bit cleaner.
Old Apr 29, 2003 | 07:51 PM
PoorMan's Avatar
thxs, good to hear.
Jeff D.
Old Apr 29, 2003 | 08:15 PM
MOREPOWER's Avatar
looks OK, but you probably had a valve stem seal leaking. that is pretty much standard on a car w/your miles
Old Apr 29, 2003 | 08:47 PM
71Monte's Avatar
quick qusetion for you Jeff, do you have the part number for the one piece pan gasket that you used. I have seen them for the old style 350, but I did not know they made them for the LT1.
Thanks,
Ian
Old Apr 30, 2003 | 11:33 AM
PoorMan's Avatar
Sorry dude, I threw the box out. I got it at O'Rellys(sp?). It is a one piece gasket. The instuctions said to install it dry without RTV in the corners like the stock gasket. Their is alot more area on the corners than the stock one btw. It also came with a gasket that I believe goes to the oil pickup thingy were the filter goes. I didn't use it though.
Jeff D.
Old Apr 30, 2003 | 12:31 PM
NOMAD's Avatar
Cool
They are all one piece for the lt-1
-Shannon
Old Apr 30, 2003 | 05:53 PM
71Monte's Avatar
-Shannon
Ahh that would make sense
Ian
Old Apr 30, 2003 | 06:51 PM
Kain's Avatar
Yeah, mine looked like that. Except the exhaust valve had a little white on it. I guess I'm running a bit hot.
Nickster 7
May 1, 2015 09:04 PM
May 1, 2015 01:14 PM
PROJECT X
Apr 17, 2015 12:13 AM
QuickSilver02
Apr 7, 2015 11:12 AM
