Does using a lift make LT headers easier to install?
Old Mar 12, 2004 | 12:22 PM
ticket_me_redz's Avatar
Or do you still have to jack up the motor to get them to fit?
Old Mar 12, 2004 | 01:31 PM
94Zpower's Avatar
A lift would make it much easier!!!
good luck.
Old Mar 13, 2004 | 07:02 AM
2cub49's Avatar
Yes you still will probably have to jack up the motor on one or both sides and remove the steering link but a lift will help ALOT.
Old Mar 13, 2004 | 09:44 AM
mongse_1's Avatar
I've found the best mod for longtubes is a tubular K-member. I was able to remove my old longtubes using a jackstand and handtool in less than 2 hours.
Old Mar 13, 2004 | 09:55 AM
1984camaroz28's Avatar
a lift makes anything easyer
Old Mar 13, 2004 | 11:20 AM
besz28's Avatar
yes a lift would. don't forget new motor mounts while you are tilting the motor. sometimes the headers will bang the floorboard.
Old Mar 13, 2004 | 01:51 PM
Achilles97's Avatar
I think it would not. I kept having to come out from under and jump up on the engine, and back and forth. I think with the car lifted this could be a problem.
Plus, I would rather be on my back tugging and pulling on stuff than have to look up and hold stuff above my head all day.
Old Mar 15, 2004 | 08:57 AM
mongse_1's Avatar
Agreed. I found it easiest to have two jackstands as high as possible when I took my LTs out. I've also found it's very hard to adjust rockers with a lift, so I wouldn't say a lift makes everything easier.
Old Mar 15, 2004 | 10:00 AM
WS Sick's Avatar
You need it up at least 22 inches for the pass side header (and the motor raised off the mounts.)
Old Mar 16, 2004 | 09:52 PM
Achilles97's Avatar
I put my passenger side header (hooker lt) in from the top. The driver's side went in from underneath.
I had the car up on ramps, then, using a jack, I put about 6" of bricks between the ramp and the tire. The wheel was probably about 16-18" off the ground.
Old Mar 16, 2004 | 09:55 PM
pappasmerf18's Avatar
so do u have to move the engine to get in the headers
Old Mar 17, 2004 | 11:37 PM
Achilles97's Avatar
I had to unbolt the passenger side engine mount and jack the engine up about 2 inches for the passenger side header.
LeftoverChinese
Jan 14, 2024 03:03 PM
Highlander
Jan 12, 2020 02:13 PM
Jason Short
Jan 19, 2015 06:34 PM
Jul 4, 2005 05:00 PM
