Does this sound right (oil change ?)
Old Oct 14, 2006 | 10:36 PM
reamo04's Avatar
Well, last night i was hanging out with a few friends (couple of them work at mechanic shops). When i started my car, they heard a wonderful ticking that we believe is either piston slapping, or a lifter. One of the guys (has a LT1 in his s10), said that he has heard that if you add 1 qt. tranny fluid when u do ur oil change (1 qt. tranny fluid, 4 qts. oil), that it will take the ticking away since tranny oil does not foam.
Has anybody else heard this? Are there any negatives to this?
Old Oct 14, 2006 | 10:55 PM
v8pwrdz28's Avatar
Re: Does this sound right (oil change ?)
i have heard of it but i would not do it. have u checked all your rockers to make sure the lash it set right?
Old Oct 14, 2006 | 11:09 PM
lt11997's Avatar
Alot of people do it if they have a sticking lifter and the tranny fluid usually cures it.
Old Oct 14, 2006 | 11:16 PM
Josh'95Z28conv's Avatar
The tranny fluid is high in detergents, and cleans any gunk that may cause a sticking lifter. Some people use diesel fuel. Or you can go buy an oil additive thats made to be added to an engine.
Old Oct 14, 2006 | 11:24 PM
StripedFomula's Avatar
would that be used for a short period of time, or would you run it the entire 3k miles?
Old Oct 15, 2006 | 01:13 AM
reamo04's Avatar
Im also kind of curious about that question.
Old Oct 15, 2006 | 08:17 AM
Personally, I wouldn't do it on anything but an old junker engine I did not care about and as a last resort...but that's just me.
Old Oct 15, 2006 | 08:49 AM
Cook Performance's Avatar
puuting one quart of tranny fluid in with 4 or 5 quarts of motor oil will not hurt a thing, it will help in cleaning out the sludge buildup in the crankcase and all the oil passages. Run it for 1,000 miles or so and then run Mobile one Synthetic.
Old Oct 15, 2006 | 10:35 AM
FlamingChicken's Avatar
usually i would only run 1/2 qt if I was gonna leave it in there. atf also breaks up a lot of carbon. been bringing rotaries back to life for a long time using the atf trick
grabbem88
Mar 18, 2015 01:25 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
jj71787
Jan 31, 2015 10:20 PM
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
