Does the mallory 685 make the car harder to start?
Old Aug 11, 2006 | 07:51 PM
speed_demon24's Avatar
I put on a ported intake manifold/58mm throttle body, and mallory 685 box at the same time, and now my car is harder to start. It starts fine, but it takes a few seconds of cranking for it to start now.
Old Aug 11, 2006 | 09:01 PM
Severous01's Avatar
Re: Does the mallory 685 make the car harder to start?
no...you may have something crossed. i installed a TB, did the "anti-coolant mod" and the crane fireball ignition at the same time and i had a high rpm due to too much play in the TB. no issues of hard starting...until my starter started failing. new starter and it's good now though
Old Aug 11, 2006 | 09:10 PM
2000GTP's Avatar
I don't have any issues with hard starting with mine. Are you sure you don't have the start retard function advanced too much? I have mine set down to 0 or 0.1, something along those lines.
Old Aug 18, 2006 | 03:39 PM
Drowned's Avatar
Mine started with hard starts... and now it's been acting very weird... it's making my engine explode Sometimes when I start it up it seems a small detonation will occur... looks like the timing goes crazy I disconnected...
Old Aug 18, 2006 | 05:00 PM
Severous01's Avatar
i have a crane ignition for sale
really though, i dont know what your problem could be. if you didnt program the ECM, didnt touch the cam/timing chain, and didnt rotate the crank without the chain attached then you shouldnt be off for timing.
does the mallory have a retard function? is it set too high?
ChrisFrez
Dec 7, 2014 06:01 PM
ro2207
Dec 4, 2014 06:18 PM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
