Does this look like valve-float to you?
I just put in new lifters/rockers/918's,springs/cam, and from what I can tell my installed height is wrong on the springs, but I wanted to get a few second oppinions incase anyone else had a dynograph look like this. The only reason I'm questioning it is I thought valve-float made the dynograph drop off like a cliff, not a 25rwhp dropoff and then hold steady.
Up to 5800 it looks like a normal LE/BRE torque curve. Perhaps more valve bounce than float after that. The package was designed to work with a certain installed height/spring load. Get the installed height correct and redyno it.
