Does a cylinder head have to warp to blow a headgasket?
Old Sep 22, 2004 | 01:46 PM
FastZinTennessee's Avatar
Just got my heads checked on the car. I apparently have a blown headgasket, but the heads checked out fine. Wondering if the head has to warp in order to blow a headgasket or not?
Old Sep 22, 2004 | 01:49 PM
WS Sick's Avatar
Re: Does a cylinder head have to warp to blow a headgasket?
No, the gasket itself can fail. But if you do blow a head gasket It is a good idea to make sure everything is flat before you put it back together (and check for cracks)
Old Sep 22, 2004 | 03:19 PM
OBE1 95Z28's Avatar
As stated above, your head gaskets can fail without warping a head. From my experience, a head gasket failure is a symptom, you need to get to the root cause of why they failed. Sources for failure are pre-detonation, heads not torqued down properly, etc.
Old Sep 22, 2004 | 08:04 PM
Well the root cause was overheating because of a clogged radiator. I can't find a blown spot in the headgaskets so now I'm gonna have to get the heads pressure tested
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Elcojoe
Nov 17, 2014 10:27 PM
