Does a 95 timing cover need clearancing for the cloyes double roller?
Old Feb 2, 2006 | 10:28 AM
Javier97Z28's Avatar
Moderator
Not sure if there's any other difference b/w the 97/97 cover and the 95 cover other than the hole for the CPS provision.
I'm going to pick up a 95 cover anyways to just eliminate that hole entirely, I think I have an oil leak there as it is w/ the CPS which is already programmed out of my PCM.
I know I need the 93-95 style hub to make up for the reluctor ring I'll be removing.
Anyone have pics of the inside of their clearanced timing cover?
Old Feb 2, 2006 | 11:35 AM
atljar's Avatar
Re: Does a 95 timing cover need clearancing for the cloyes double roller?
No pics, but mine needed it.
I sprayed my chain down with a little grease, and then installed timing cover. Turned motor over by hand, removed cover.
Then dust the cover with chalk/powder/whatever, and it will show you where it rubbed.
Old Feb 2, 2006 | 02:03 PM
96ta(nick)'s Avatar
My 96 did not but my friend's 95 did require a little clearancing.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
